Looking for help for a 600-900 USD build
Dank tech
Commendable
Dec 27, 2016
196
Approximate Purchase Date: Somewhere around March or April 2019
Budget Range: 600-900 USD or 45000-70000 inr
System Usage from Most to Least Important: Gaming and coding work
Are you buying a monitor: Yes
Parts to Upgrade: entirely new build
Do you need to buy OS: No
Preferred Website(s) for Parts: www.mdcomputers.in www.primeabgb.com
Location: City, State/Region, Country - Bangalore,India
Parts Preferences: I'm open to anything as long as there's a service center in my country but I have been looking into the Rx 580
Overclocking: Maybe in the future once I understand it😀
SLI or Crossfire: Maybe
Your Monitor Resolution: 1920×1080
Additional Comments: My monitor doesn't have to be included in my budget but if you can find something which will fit in it that would be great (I might be able to up my budget just a tiny bit)and I need it to be future proof for maybe around 3-5 years or it should be easy to upgrade a part if it breaks or is outdated with today's games.The websites i used here are just for price reference, I will mostly go around the local computer shops since the prices there are cheaper
And Most Importantly, Why Are You Upgrading: Need a pc
Thank you guys in advance for helping me out and giving your time towards helping me :)
I would suspect that there should be a 2060 by then, but not much is known about what it will be like or how much it will cost. There might potentially be Ryzen 3000-series CPUs by around that time as well. So far, there are only rumors about when these components might get released.
It would probably be better to ask this question closer to when you intend to build your system. Prices of components will probably change over the course of the coming months, and it's very possible that there will be new graphics cards and maybe even CPUs coming out by then, which could change recommendations.
Even I was thinking of that, is the possible new rtx 2060 in that list by any chance?
