Hello all who read this
Bought the take classic 5.1 and a receiver AVRS920W Denon 7.2
After building my pc and desk, im ready to setup the speakers. already know how to position them.
problem is dont know for sure the options on how to wire them together positive goes to positive an same with negative that much i know. less wires equals cleaner look
Is it possible to bypass "not use" receiver and go direct to soundblaster z? if so whats correct configuration or way to do it? here is my thought.. each pair of speakers negative go together same with positive, ending with only one positive lead for each pair of speakers. like i said, i dont know.
If receiver is needed its self explanatory to certain point. im wondering instead of two leads from each speaker can i wire each pair together leaving two leads instead of four? having four wires per 2 pair of speakers is alot of wire to manage and make look neat!
on receiver it has 3 connection points that says monitor, im assuming go from there to sound card?
where on subwoofer to connect an go to receiver? subwoofer has 2 positive an negative connections an line in/sub in, left is white right is red. got my own wire I'm using 14awg clear
appreciate any help on this
