Metalmario66 :
DRL1966 :
Metalmario66 :
DRL1966 :
Well from what I understand is that it will not show up at all, it's a 2 month old drive (which is fully replaceable through the manufacturer) but I need to retrieve my work (data) off it first and they do not recover media for you only replace and or recommend a group that will recover data but they want to charge me nearly $600 for that and I also understand that this happens sometimes that the drivers for the flash drive will not load properly which makes it stop working; anyway all my other flash drives work properly still but not this one and I tried it in many other systems windows 10, 8, and 7 and nothing.!!!
Metalmario66 :
How did it brake? Is it just a error or is the circuit board broke?
I know this is a stupid reply but do u think something became "unsoldered" like ur USB part broke?
Well that's not such a stupid reply at all because from doing some online research including a bit on YouTube I'm seeing that the USB connections sometimes fail, meaning that the solder comes apart and I seen how one guy in Hawaii is making videos on how he retrieves data of any type of memory device and most often than none the failing flash drives are coming unsoldered and causing issues like this but the problem is I'm not exactly sure how to do what they do and not mess it up even more, and if I work on it myself it voids the warranty which I don't really care at this point because the data is more to me than the cost of the flash drive; however, if I make a mistake I could mess up the very same data I need and be out the replacement to boot.!!!
Don't worry learning how to solder is easy. Just make sure u don't put a huge glob of it on there. U don't want to connect solder to other solder meant for something else, that can cause a problem. Although I've vpnever soldered a USB before and never done it on a flash drive either.
Thank you for the advice and the vote of confidence and I might just try to at the very least just melt down what solder that is already there and let it fill in any gaps that may have taken place and see what that does; I'm hopeful but not very confident that it will work but stranger things have happened; so right than, here goes nothing,,,LOL. thanks again and have a great day.!!!
