looking for led fans
houdinii1212
30
anyone have sugestions for realy bright led case fans?
i have an air 540 case with a realy big window but its pitch black in there i have a corsair water cooler that has a blue light up logo so i want some blue fans to light up the inside and outside.
a quality fan is a must but im realy want bright ones. 3 140mm and 2 120mm
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100006519%2050013802%2040000573&IsNodeId=1&SubCategory=573&Manufactory=13802&SpeTabStoreType=1
Cougars are bright.
Id recommend not getting LED fans. For around $30 you can get RGB LED strips that will look much better than fans. You can find kits that come with the remote, LEDs, and the power adapter for pretty cheap. I just put some in my Corsair 450D and I really enjoy them. They are very easy to install, its as simple as peeling the 3M tape off the back the LEDs and running then around the inside your case. Run the wires out the back your case, and plug in the power. I can send you pics on how i did it if you'd like.
Here's a kit similar to what i have:
http://www.newegg.com/Product/Product.aspx?Item=N82E16803193013&cm_re=RGB_LED_strips-_-03-193-013-_-Product
