Hello,
I'm looking to add a GPU to support an additional 3rd monitor.
I have a HP P7-1510 system that has integrated video with 2 DVI outputs that can be used concurrently. I was hoping to just add a cheap low power card to the pci-e x16 slot, but the system specs page states "Either integrated graphics or the PCI Express x16 slot are usable at one time; they are not usable concurrently."
The system also has 3 pci-e x1 slots. I'm guessing I can use at least one of these concurrently with the integrated graphics since it hasn't been stated otherwise on the system specifications page.
Which route should I go, should I try to just use the integrated graphics with another card plugged into pci-e x1 slot or just use the pci-e x16 slot? In either case, what would be a good card to go with? I'm hoping to spend sub $100, but am willing to maybe go up to $150.
Here are the monitors I'm using:
HP w2408h (VGA, HDMI)
BenQ RL2755 (VGA, DVI, 2 HDMI)
Asus VS247H-P (VGA, DVI-D, HDMI)
Motherboard: Joshua-H61-uATX
PSU: 300W
Thanks!
PSU: 300W
Thanks!
