[SOLVED] Looking for monitor for 1440p144
Shuten
74
I am trying to find a monitor to game with. As the title says 1440p144hz,
preferences:
32" curved preferably
have rtx 2080, so probably one with gsync, though i hear that nvidia cards are compatible with freesync now
for my budget, ive put aside $500
For less than 500 dollars you won't find ANY 32" 1440p 144hz display that is better than this one. If there was one, then I and many others here would have bought THAT instead of this. So far, it's been flawless with my RTX 2060 Super.
https://www.amazon.com/LG-32GK650F-B-Monitor-FreeSync-Technology/dp/B07FLGR2PN
im guessing there arent many curved monitors that can match this one? also i do remember seeing a thread/post mentioning the px329 was just as good if not better than the lg 32gk650F
Yes, that display has fairly good reviews, however, there are multiple references to the fact that there is potentially serious ghosting issues on that display, G-sync compatibility seems to be very spotty and in some cases reportedly results in absolute black screen problems and has maybe the wobbliest stand ever seen on any modern monitor. In fact, that is the primary notation for every review is the fact that a slight breeze is liable to knock the display over because the stand is so crappy. That and the G-sync issues are primarily why I avoided that and went with the LG.
But, if that's not an issue for you and if you can find concrete evidence that the G-sync issues have been resolved, then it might be a a good option too.
