Looking for parts . How do I tell what kind of laptop this is.
dinodon
50
I picked up a Lenovo Ideapad 11G3G. It has widows XP installed. Is this a S10 model????
I'm looking for new fans and a battery.
Hello Dinodon, and welcome to Toms!
Based on what little information I can get from Lenovo, I don't think that "11G3G" is the full model number, it is just the "product number". The number you are looking for is the "type" number, which from what I can find is "4333-???". With those numbers, your search should be much simpler.
Best deal on a battery: http://www.amazon.com/2200mAh-Laptop-Battery-Lenovo-IdeaPad/dp/B00QYXRCLW/ref=sr_1_2?ie=UTF8&qid=1430841086&sr=8-2&keywords=Lenovo+4333+battery
Best deal on a new fan: http://www.ebay.com/itm/like/320573215160?lpid=82&chn=ps
Hope this helps!
New fan as in its dead or slow? You can't just stick a faster fan inside a laptop. Do you want an extended battery or just the same size one?
It's noisy. I am looking for a replacement NEW CPU fan.
There is going to be a part number on the cpu fan and the battery. Try that?
Hope this helps!
- Harrison Whitmarsh
Lincoln Nebraska USA
