Looking for pc building advice
Aug 31, 2018
7
is this pc going to even work(I am a neewbie)
Btw I know how to put it together now that i have read many forums but i am looking for some kind of confirmation that this is going to work
Graphics:https://www.amazon.com/PNY-GeForce-Blower-VCGGTX1080T11PB-CG2-Graphic/dp/B06ZY1R814?SubscriptionId=AKIAIPHVZTVH6LZ5BFZA&tag=hawk-future-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B06Y3V38R2&ascsubtag=pcg-1451613433856588844-20&th=1
RAM:https://www.amazon.com/gp/product/B01K7V0DRG/?tag=hubacct9792-20&th=1
CPU:https://www.amazon.com/dp/B07G25SD1P
board:https://www.amazon.com/ASRock-X399-TAICHI-sTR4-Motherboard/dp/B074J5R36W/ref=sr_1_1?tag=gimdna08-20&s=electronics&ie=UTF8&qid=1527705345&sr=1-1&keywords=ASRock+X399+TaiChi&dpID=51-cEiYsr7L&preST=_SX300_QL70_&dpSrc=srch
cooler:https://www.amazon.com/Enermax-Exclusive-Threadripper-Technology-ELC-LTTR360-TBP/dp/B074ZLQZG2?th=1
case(option):https://www.amazon.com/DIYPC-Alpha-DB6-Acrylic-Computer-motherboard/dp/B00D3Y7P44
or
use a cardboard box like Linus?
Psu:https://www.amazon.com/EVGA-SuperNOVA-Modular-Warranty-120-GP-1000-X1/dp/B0797D5WHH
I'm a newbie too, I would suggest using PcPartPicker. It will tell you if your components are compatible, and also where you can get the best (online) price on each component, as well as user reviews.
I built my first one about 5 years ago, and by ordering online from multiple vendors, I came in far enough under budget to buy a new case and PSU.
Never had so much as a glitch with the combination of components.
Thanks,ps there are a lot of important parts that are missing ex. case
