Question Looking for PSU - Quiet, excellent quality, modular, probably around 500W
Jan 22, 2025
I'm currently using a Ryzen 7 (TDP 65W) with an RTX 3050 6GB (TDP 70W) and don't really plan on going (much, if at all) beyond that. I prefer relatively quiet, stable and energy saving systems over the "full size" gaming rigs.
However, long story short: My Corsair HX520 (which I love) is probably around 15 years old at this point. It seems to still work flawlessly. BUT: The PC was in a smokers room for a very long time and the fan became somewhat audible in the past years. Since I don't expect a fan to remain silent and well running after 15 years of smoke-dust, I guess I should start considering a replacement.
So, what could I look for? I checked the forum here and the pinned threads, especially the one which details the quality of e.g. Corsair. But I did notice that most of the stuff that's considered great quality seems to start way above 500W, which is obviously total overkill for my system. I'd guess even the 500W are more than generous already. I'd love to get me another Corsair, since this one served me well, but seems like top notch models do not exist in this power range.
Any suggestions?
That's quite true.
You may have to settle for 650.
Within the last 3 months, I saw a couple of recommendations for higher quality low wattage units, but I did not make note of them. Much to my consternation.
Generally...I'd look at Seasonic and Super Flower. No doubt other posters may make specific recommendations?
Maybe the Seasonic Focus GM 550. I think it is semi-modular. Maybe you insist on "full modular" for some reason?
https://www.amazon.com/Corsair-RM1000e-Modular-Low-Noise-Supply/dp/B0BYR1BXC6?th=1
Above Corsair is I think 750 watt, but has a decent rep and is often on sale.
I'll be following this thread for my own sake as I may need a new PSU myself.
You were smart to buy a psu with a good warranty.
A good warranty is one good clue as to quality.
Look to Corsair rm and Seasonic focus/vertex for example.
Extra strong is good, first, it allows for a future graphics card upgrade, the most common component needing an upgrade.
Next the psu can loaf in the middle third of it's range where it is most efficient. The fan may actually not need to run.
Today's graphics cards can have high demand peaks, well above the nominal power draw.
+/- 10w is usually a small cost differential.
Two to look at for starters:
Seasonic vertex GX-750 with a 10/12 year warranty:
https://www.newegg.com/seasonic-vertex-gx-750-750-w/p/N82E16817151259?Item=N82E16817151259
Corsair RMx 750x with a 10 year warranty:
https://www.newegg.com/corsair-rmx-...s-gold/p/N82E16817139335?Item=N82E16817139335
The reason there are no decent 400-500w PSUs anymore is because the production costst are the same as a 650w while the consumer expects it the buy it for $10 cheaper per 100w less. The manufacturer can't make money on the lighter units.
Cheapest PSU with the latest ATX3.x spec and very good LLC platform is https://pcpartpicker.com/product/Xm...-modular-atx-power-supply-ps-spd-0650mnfabu-3
The next recommandation is https://pcpartpicker.com/product/jZ...ular-atx-power-supply-corereactorii650g-bkcus while the 750w costs the same https://pcpartpicker.com/product/zf...ular-atx-power-supply-corereactorii750g-bkcus
https://pcpartpicker.com/product/LY...tified-fully-modular-atx-power-supply-sl-650g is a very decent unit too
https://pcpartpicker.com/product/ph...-modular-atx-power-supply-ps-tpd-0850fnfagu-4 is a steel for 850w
The RM750x 2024 costs you $119 https://pcpartpicker.com/product/JP...-fully-modular-atx-power-supply-cp-9020285-na and a Focus GX with OCP issues sets you $136 back. The Vertex is €130 https://pcpartpicker.com/product/76...-fully-modular-atx-power-supply-vertex-gx-750
When you look at the 750w chart from HWbusters/Cybenetics you see the Corsair gives you the best perfomance, followed by the Thermaltake GF3 and XPG.
Thanks everyone for the input. The fan on my PSU seems to have calmed down a little, so I'm probably not replacing THAT soon.
However, from what I've read here, I'd probably go for a Corsair RM 750 if a replacement is needed.
Just because a PSU says it is 650W doesn’t mean it will draw more power from the mains supply.
If the efficiency is nominally the same at a particular power output the PSU will draw the same amount of current from the mains.
Check the datasheets for the PSUs you are considering. If the prices are comparable choose which suits you.
I would tend towards a good 650W over a 500W if only for the headroom. The benefit to the extra headroom is that the PSU isn’t ‘stressed’ as much. All things being equal it should last a little longer and internally to the PSU generate less heat as it approaches the limits of the lower rated unit again causing less wear and tear.
