Hello.
I've been a gamer for many years now, but I'm ashamed to say that I'm really not very technologically literate. I can solve some problems (often with the help of Google), but I encounter just as many that I can't. So I figured I'd ask some much more tech-savvy people for advice! (Thanks!)
Generally, my problems revolve around not knowing how to optimize my system for my gaming needs. Regardless of how powerful a system I may buy, it never seems to be at the quality level that Google tells me it should be.
Anyways, my current conundrum is trying to figure out why my high-end gaming laptop is having trouble running higher-end games - in this case The Witcher III -
Wild Hunt and Divinity II - Original Sin. I have tried turning down the settings significantly, but regardless the gameplay is still choppy, with substantial freezing. According to Task Manager, the problem seems to be either memory or my GPU hitting 100% use. Currently, my memory usage is at 97%+, and my GPU is at 75%; though yesterday the GPU was at 97%, before I turned down the settings. The memory usage in particular boggles my mind, since I have 16gb of RAM. I'm not sure on the VRAM, but I think it was 3gb.
I've done some Googling of the quirks for Witcher III, including that certain settings, like Nvidia HairWorks, are huge resource guzzlers with very little visual impact, so I've disabled those. The same googling has told me that with my system, I should be able to run almost everything on Ultra, assuming I'm understanding it right, and still manage 57+ FPS. However, I've turned many of the settings off/low or medium, leaving only a couple of the supposedly easier-to-run effects on high.
Can anyone explain to me why these games aren't running as I thought they should? If it helps, here's some information on my system (just ask if you need more, and I'll try to find it if I know how):
CPU: Intel Core i7-6700HQ @2.60GHz
RAM: 16GB
GPU: Nvidia GTX1060
HDD: 1TB (the games in question are on this drive)
http://
[strike]One thing I am wondering is if my system is somehow using my integrated Intel graphics by default for these games. I'm not sure how to check this, but I don't see why it would default to it.[/strike] The game is using my GTX1060.
Edit: Adding more info as I think of it:
The choppy gameplay I'm experiencing feels to me more like it's caused by the memory capping, actually. Though I don't have any tech-know to prove this. The reason I say this is because:
-My frames per second are not consistently low. It just spikes. I'll be running along smoothly, but then the game will just freeze for a split second, then hop ahead. These little episodes of freezing happen almost constantly, with occasional larger episodes (1-2 seconds long). This most often happens when I'm moving quickly across the field (i.e. galloping on my horse), which presumably causes the game to have to load the area in front of me faster than usual. It also sometimes happens during hectic fights. If the problem was my GPU, wouldn't my FPS be consistently low? As for the CPU, I'm not sure how that manifests itself in poor gameplay. I have experienced similar freezing in games from before I had my current laptop. My previous laptop had very serious memory issues, and I occasionally even got Global Memory Allocation Failures. The current problem feels similar, but it hasn't crashed yet. But again, I'm basing this entirely off past experience, with no actual technical knowledge.
RAM: 16GB
GPU: Nvidia GTX1060
http://
