LOOKING FOR WIRELESS DISPLAY Motherbord
Mohommad Almawlani
6
Hi Dear IT's,
Im Looking for widi (Wireless Display) Function on An Desktop PC To Upgrade My Work Computer
Im Looking To Connect My Smart T.v As Extended Monitor For PC
T.v Model:LG 42LB5820-TP (Support: Mira Cast _ Intel's Widi _ WiFi Direct)
Processor: Intel Core i3 2120 @ 3.30GHz
RAM: 4 GB DDR3
Looking To Update With CASE+Motherbord+USB3.0+4GB RAM+ 6OR More BackPanel USB
Current PC Information
CPU
Intel Core i3 2120 @ 3.30GHz 46 °C
Sandy Bridge 32nm Technology
RAM
4.00 GB Single-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
Foxconn H61MXT1/F2/-S/-V (CPU 1) 33 °C
Hard Drives
466GB Seagate ST500DM002-1BD142 ATA Device (SATA) 36 °C
1863GB Seagate ST2000DM001-1CH164 ATA Device (SATA) 40 °C
Optical Drives
HL-DT-ST DVDRAM GH24NSB0 ATA Device
Looking Around 300$ Update
You would have to get a CPU that supports it first (like the G3240). Socket 1150
I'm using one here with the ASUS H97M-E. But I dont use the widi function (dont have the widi adapter)
No Other Solution
I Find Some Motherbord's With Widi LGA1155
No Need To Change All Part Its Work Computer
And I have The Smart T.v
sorry the processor is not in pool to change to lower model
the i3 batter then what you write if i need to change processor i well cancel all job
Please Check this Motherbord
" Gigabyte GA-B75M-D3H ATX Motherboard "
