Hi,
I'm running into an issue with my new monitor (LG 34GN850-B 34 ) and before going through the refund/replacement process, I thought I'd reach out and see if anyone can help. (I should mention this post is in not reference to the length of the cable, but the gold/silver connector that plugs into the display port jack itself).
I have tried connecting three different display port cables. Two of them were 10 feet, the other one was short, like 4-6 feet. For these three, I get "no signal" message, and my computer won't display. But the power is connected, as I can still use the joystick power button and adjust monitor settings. For each of these three cables, the connection inside the Display Port jack in the back on the monitor is VERY loose (but sits fine in my graphics card). I mean, it's so loose that, it doesn't feel connected all the way and the cables fall out with with very little effort. And even when I tried holding the cable in place, as far as it goes in, it still doesn't work.
That said, I do have one cable that DOES work. The cable that does work, it's another 4-6 foot cable, but what I think is the biggest difference is the length of the actual connector that goes into the display port. It's just slightly longer than the other three and doesn't feel as loose when connected, and so far I have no issues using my computer with it. (Knock on wood, this one doesn't crap out on me).
My question is, has anyone run into an issue like this where some cables are very loose, some aren't, with different length connectors? Any solution? Are different connector lengths even a thing? Or did I just get lucky having one with a length that actually works? My goal was to replace the 4-6 foot cable with the 10 foot so that I can have better cable management, but now I don't know if I should keep looking for a new cable that shares the same length as the one that works, or just refund the monitor.
Any insight is appreciated.
Thanks
Thanks
