I was browsing discord after playing Rematch for 2 hours. Then suddenly my screen went black and "no display" showed up, but I still have sounds because I can still hear videos playing and my friends chatting in the background.
I noticed the GPU fans went full speed so I tried forcing a reboot by holding the power button for 5 seconds but the PC won't turn off, so I pulled the power plug from the PSU.
After plugging the power back in, my PC won't turn on. It did light up for a milisec before turning off again, but then the PC won't even turn on at all after pressing the power button.
I do have a faulty RAM slot that has prevented boot before, it occurs only after I cleaned my PC, and removed the RAM. But I only need to reseat the RAM a few times, and it would went back to normal.
So far, I've tried:
- Removing CMOS for 5 minutes, and putting it back in. Didn't work
- Reseating the GPU, didn't work
- Tighten the power cables into my PSU and GPU. Didn't work too
- Flipping the power switch from the PSU. The PC did turn on for a little longer for like 10 seconds, but it won't boot and it would turn off and refusing to turn on again.
- Removing the GPU. Kinda works I guess, since the PC is not shutting down until i press the power button again. Gpu and boot light indicators lit up from the mobo.
My specs are:
- CPU: i5-10400f
- GPU: MSi RTX 3080 Sea Hawk 10G, bought it second hand from August '24, seller said it was only used for office and gaming purposes.
- Mobo: Asrock B460M Pro4
- RAM: 2x8GB DDR4. Both are different brand, one is GEIL Evo Potenza, and the other one is a Klevv Value. Both running at 2666Mhz
- PSU: Bitfenix Whisper M 650W 80+ Gold
So far, I've tried:
My specs are:
- CPU: i5-10400f
