JoshRoss :
7% and 2Gigs are very standard measurements. To check any running processes, you can go to Task Manager and look if there is anything suspicious, maybe a lot of random applications? See if there is anything there and let me know. Also, you can run AdwCleaner and Malwarebytes and get the logs here so I can look over them.
There is no suspicious applications running. Just normal programs like Steam, Discord. There is the log files:
# AdwCleaner 7.0.1.0 - Logfile created on Thu Aug 24 19:22:45 2017
# Updated on 2017/05/08 by Malwarebytes
# Running on Windows 7 Ultimate (X64)
# Mode: clean
# Support:
https://www.malwarebytes.com/support
***** [ Services ] *****
No malicious services deleted.
***** [ Folders ] *****
Deleted: C:\ProgramData\IObit\Advanced SystemCare
Deleted: C:\ProgramData\Application Data\IObit\Advanced SystemCare
Deleted: C:\Windows\System32\config\systemprofile\AppData\Roaming\IObit\Advanced SystemCare
Deleted: C:\Program Files (x86)\Common Files\IObit\Advanced SystemCare
Deleted: C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\IObit\Advanced SystemCare
Deleted: C:\Users\Gallows\AppData\LocalLow\IObit\Advanced SystemCare
Deleted: C:\Users\Gallows\AppData\Roaming\IObit\Advanced SystemCare
Deleted: C:\ProgramData\IObit\ASCDownloader
Deleted: C:\ProgramData\Application Data\IObit\ASCDownloader
Deleted: C:\ProgramData\Audyssey Labs
Deleted: C:\ProgramData\{74E9F814-C737-42CC-B721-DBBC4059367A}
***** [ Files ] *****
No malicious files deleted.
***** [ DLL ] *****
No malicious DLLs cleaned.
***** [ WMI ] *****
No malicious WMI cleaned.
***** [ Shortcuts ] *****
No malicious shortcuts cleaned.
***** [ Tasks ] *****
No malicious tasks deleted.
***** [ Registry ] *****
Deleted: [Key] - HKLM\SOFTWARE\IOBIT\ASC
Deleted: [Value] - HKLM\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules|{281F6AF0-62EF-46BA-9AA8-398B3AE03324}
Deleted: [Value] - HKLM\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules|{F2A08313-1662-4BB7-BEA8-85DA7B888C23}
***** [ Firefox (and derivatives) ] *****
No malicious Firefox entries deleted.
***** [ Chromium (and derivatives) ] *****
Startpage deleted:
http://www.search.ask.com/?o=APN10640A&gct=hp&d=473-104&v=n9397-133&t=4
Startpage deleted: about:blank
Startpage deleted:
::Tracing keys deleted
::Winsock settings cleared
::Additional Actions: 0
C:/AdwCleaner/AdwCleaner[S0].txt - [2452 B] - [2017/8/24 19:22:9]
########## EOF - C:\AdwCleaner\AdwCleaner[C0].txt ##########
Malwarebytes
-Log Details-
Scan Date: 8/24/17
Scan Time: 9:52 PM
Log File: 5520e6b6-88fd-11e7-b3ef-6cf0496f2662.json
Administrator: Yes
-Software Information-
Version: 3.2.2.2018
Components Version: 1.0.186
Update Package Version: 1.0.2652
License: Free
-System Information-
OS: Windows 7 Service Pack 1
CPU: x64
File System: NTFS
User: OLD\Gallows
-Scan Summary-
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 356632
Threats Detected: 11
Threats Quarantined: 0
(No malicious items detected)
Time Elapsed: 9 min, 49 sec
-Scan Options-
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Detect
PUM: Detect
-Scan Details-
Process: 0
Module: 0
Registry Key: 0
Registry Value: 0
Registry Data: 0
Data Stream: 0
Folder: 0
File: 11
PUP.Optional.MindSpark, C:\USERS\GALLOWS\APPDATA\LOCAL\GOOGLE\CHROME\USER DATA\DEFAULT\LOCAL STORAGE\http_gamingwonderland.dl.myway.com_0.localstorage, No Action By User, [259], [240305],1.0.2652
PUP.Optional.MindSpark, C:\USERS\GALLOWS\APPDATA\LOCAL\GOOGLE\CHROME\USER DATA\DEFAULT\LOCAL STORAGE\http_gamingwonderland.dl.tb.ask.com_0.localstorage, No Action By User, [259], [240306],1.0.2652
PUP.Optional.NewTabTV, C:\USERS\GALLOWS\APPDATA\LOCAL\GOOGLE\CHROME\USER DATA\DEFAULT\LOCAL STORAGE\http_search.newtabtvsearch.com_0.localstorage, No Action By User, [2382], [359410],1.0.2652
PUP.Optional.NewTabTV, C:\USERS\GALLOWS\APPDATA\LOCAL\GOOGLE\CHROME\USER DATA\DEFAULT\LOCAL STORAGE\http_tr.newtabtv.com_0.localstorage, No Action By User, [2382], [359416],1.0.2652
PUP.Optional.NewTabTV, C:\USERS\GALLOWS\APPDATA\LOCAL\GOOGLE\CHROME\USER DATA\DEFAULT\LOCAL STORAGE\http_tr.newtabtv.com_0.localstorage-journal, No Action By User, [2382], [359416],1.0.2652
PUP.Optional.MySearch.Generic, C:\USERS\GALLOWS\APPDATA\LOCAL\GOOGLE\CHROME\USER DATA\DEFAULT\LOCAL STORAGE\http_gettvstreamnow.dl.mysearch.com_0.localstorage, No Action By User, [7968], [383401],1.0.2652
PUP.Optional.FullTab, C:\USERS\GALLOWS\APPDATA\LOCAL\GOOGLE\CHROME\USER DATA\DEFAULT\LOCAL STORAGE\http_search.fulltabsearch.com_0.localstorage, No Action By User, [2044], [376101],1.0.2652
HackTool.Agent, C:\PROGRAM FILES (X86)\DFX\PATCH.EXE, No Action By User, [440], [1570],1.0.2652
PUP.Optional.Plumbytes, C:\USERS\GALLOWS\DOWNLOADS\ANTIMALWARESETUP.EXE, No Action By User, [8123], [123575],1.0.2652
PUP.Optional.Plumbytes, C:\USERS\GALLOWS\DOWNLOADS\ANTIMALWARESETUP (2).EXE, No Action By User, [8123], [123575],1.0.2652
PUP.Optional.Plumbytes, C:\USERS\GALLOWS\DOWNLOADS\ANTIMALWARESETUP (1).EXE, No Action By User, [8123], [123575],1.0.2652
Physical Sector: 0
(end)
