So i've been having a lot of problems with my PC recently, not sure if they're all related, though I could use some help.
I got a PC that I built, running Windows 7.
- AMD FX-6300 Vishera 6-Core 3.5GHz
- Western Digital WD Blue WD10EZEX 1TB 64MB
- CORSAIR Enthusiast Series TX650 650W
- SAPPHIRE 100354OC-2L Radeon HD 7870
- G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3
- ASUS M5A97 LE R2.0
Basically here's my problems: When I boot for the first time in the morning, it will hang on "Loading windows...". I have to manually reset the PC, and it loads perfectly the second time. Sometimes my PC will freeze just after I log in and it starts booting up my startup programs. This does not happen every time, just sometimes. After ignoring the issue for a while it got worse, I could no longer boot my PC as it would always freeze during the first few seconds of starting my startup programs (after logging in).
I gave up and installed Windows 7 again, I just installed it and told it to put all my old files in a Windows.old. (Did not reformat). I had sensitive data that I couldn't lose.
Anyway, the same problems are happening again. I ran a diskcheck through command prompt and it said the disk wasn't dirty. What do I do?
