Loud High Pitch feedback noise when using Two quickcam mes..
G
Guest
Guest
Archived from groups: alt.comp.periphs.webcam (More info?)
Here's my problem, I would appreciate any feedback and will try
anything at this point. Logitech tech support wouldn't even talk to me
and told me to call MSN, terrible after pruchase service, I'm really
disappointed with Logitech.
I hooked up two Quickcam Messengers to two PCs I have in my house that
are at the extreme ends of the house. If I use either one to talk to a
friend (not using a quickcam messenger) it works perfectly, but a high
pitched screeching type sound will occur when the two quickcam
messengers that I have in my house are used to talk to eachother using
msn messenger. I confirmed that the same problem happens using Yahoo
Messenger.
Using a headset with a mic will solve the problem, but id like to be
able to use the mic from the quickcam and the sound from the
spakers..yes it's sad that two people in the same house are video
conferencing, but it's novelty and the fun will wear off , untilt hen
I want this to work and since I haven't tested it with another person
outside my house that also has a Quickcam Messenger, it's a
possibility it will also occur.
Just want to know if anyone has experienced similiar problems and has
been able to solve it without having to use a headset.
Thank you.
On 26 Jun 2004 12:13:57 -0700, dss_canada2@hotmail.com (Rockstead)
> Messenger.
> Thank you.
That's acoustic feedback.
Noting is broken or faulty on your equipment.
The fault us yours. You need to lover the volume on your
loudspeakers or/and mic volumes. The volumes are set to high!
> > Messenger.
> > Thank you.
Of course have your friend on the other side also to lover
the volume on his/her mic and speaker.
Don't pump up the volume! 🙂
<snip>Slayer, were you born an arsehole or have you had to work at it?
Martynz<end>
i had to work at it whats your excuse?
regards slayer
if the following image offends then dont look at it...
,/_ /
/'_'/' '/'_'7,
('( ' ' _~/
'\' \ \ \ _7
slayer in da house annoying the people
ERROR 404 SIG NOT FOUND . END OF INSTRUCTION , PROGRAM FAILED TO
INITIALIZE. KILL ALL ENEMIES OF THE UK AND COALITION FORCES NOW !!!
SOME PEOPLE ENJOY SIPPING FROM THE FOUNTAIN OF KNOWLEDGE...........
PERSONALLY ,,,, i like to take huge gulps..........
remove my shorts to email me direct....
http://www.rselby.com/tips.htm windowx xp tips
regards slayer
phlem1@myshortsbtinertnet.com
Martynz
> Messenger.
Perhaps when you say something into your mic on machine A, it comes out of
the speakers on machine B, into the mic on machine B, out of the speakers on
A, in the mic on A and round and round. This is a classic feedback
problem, as already mentioned.
If you use a unidirectional mic pointed towards yourself AND away from your
speakers, you should have better luck.
As already mentioned, turning volumes down will help, your biggest problem
is that the sound from the speakers is above the threshold of the mic.
Either make the mic more directional, so that it doesn't pick up the sound
from the speakers, or lower the speaker volumes and/or the mic recording
level.
Ben
A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
Questions by email will likely be ignored, please use the newsgroups.
I'm not just a number. To many, I'm known as a String...
