Hi Guys!
The last few weeks my PC has been making some loud loading sounds (hard to explain the sound) intermittently. It seems to mostly be when my CPU is over 50% load but also happens less than that.
Can't figure out if the sound is coming from the Hard Drive or PSU. I can usually make the sound go away if a tilt my PC on a sharp angle.
My case makes it nearly impossible to access the PSU.
My system specs - Ryzen 5 2600, RX580, 16gb Ram, Segotep 600W PSU, WD 2TB HD, WD 240GB SSD
I've removed all the dust etc from the case and fans and tightened all the screws as I thought that may be contributing to the problem but it didn't make a difference.
Appreciate any help or advice.
Cheers
Cheers
