Low cinebench score i7-8700k
Sep 1, 2018
Problem: My cpu temperature goes beyond 95% while rendering. the score is just 1030cb , even lower than the official i7 3930k
Link to view my computer spec: https://ibb.co/cSiTXz
Link to view my cinebench score: https://ibb.co/bPaWkK
If you don't want to view the link, below is a short summary
My current cpu: i7 8700k
gpu: no separate gpu, just the gpu inside the cpu
ram: 2133hz crucial technology 8GB
Please help! Thank you so much!!!! I am so helpless now.
If your temps are exceeding 95 celsius, then you are thermal throttling and that will cause low scores. You're going to need to fix your overheating problem. What cooler do you have, and are you sure it's mounted properly?
If those are indeed your temps, you have a thermal issue which would be causing low scores. Although OC'd, I get ~1650cb in Cinebench test using my 8700k. RAM frequency plays a role as well in the score if I remember, but not causing anything like what you are experiencing.
Thank you for answering, my water cooler is Kraken X62 280mm water cooler. But I overclock my cpu to 4.7MHz always. My cpu temperature is around 55 degree in normal working environment. When I do the cinebench testing, the temperature is really high which make me think that my water cooler is not very efficient. My ram is just a 2133Mhz 8GB ram. A very cheap ram. Haha.
