Low CPU and RAM clock/usage as well as low GPU usage in games. Help?
Zaneisback
71
Hi all! I noticed after attempting to diagnose my low FPS issues on any setting in games that my GPU usage was incredibly low, around 50% maximum and average. After trolling the forum and the rest of the internet came up with no solutions, I decided to determine if the issue was a CPU or RAM bottleneck. Low FPS by the way is 30.8 FPS on average. It never seems to go up very much.
The answer? Well kind of maybe.
I found by looking at the performance tab in task manager that CPU clock was 1.32 GHz and games were only using 56% of it at max, and my RAM was clocked at 533 MHz.
The kicker about this situation is it CAN'T be my card as I replaced it just today with a new one. My first thought was that this was a motherboard issue, but I can't be sure.
Please if you have any idea, let's figure this mess out together.
Specs:
GTX EVGA 780 Not OC replaced GTX MSI 760 4GDR5 OC/TF
MSI 970 gaming motherboard
FX-8350 CPU (Supposed to be as specified in BIOS) clocked at 4.0 GHz
Patriot Sector 5 RAM Factory clock 1066 Mhz overclocked to 1866 stable (Problem still arises UN overclocked)
CM 690 II advanced case
Thank you if you do end up replying. I appreciate it.
That's exactly what I've been keeping up with ever since I discovered the problem. I just double checked and every driver is up to date as well as BIOS version. Even though the problem has persisted after updating the BIOS and multiple drivers.
After calling MSI all that they could do was issue an RMA. Everything is plugged in and nothing is underclocked in the BIOS. I will likely be buying a Gigabyte board next month as that was recommended by a good friend of mine. Do you have any solid motherboard choices that I should go after that's within $150? I would greatly appreciate it.
