Low CPU score in Firestrike Benchmark
Apr 25, 2018
11
Im only getting 13,000 barely in firestrike with my Ryzen 1800x overclocked to 4mhz. I have tried lowering the overclock as well to see if thay fixes it and did not work. Also I even changed the power options in windows to see if that fixes it by turning it to high performance and updated the chipset drivers so that balanced Ryzen mode could be used. Nothings works, it is consistent at 13000 score and 41 FPS. My GPU is a Gigabyte Vega 64 OC edition and ik getting great graphics scores of 24k. Not sure whats going on but clearly my CPU is not functioning as it should. Please assist.
- Run a different benchmark like Geekbench 4 to look specifically at the processor. 3Dmark is only good for giving an overall idea of gaming performance. It makes it difficult to draw meaningful conclusions from the scores IMO.
- How are your temps?
Firetrike is geared toward gamers and graphic cards. I would instead try something like Cinebench. https://www.kitguru.net/components/cpu/luke-hill/amd-ryzen-7-1800x-cpu-review/5/ shows what you can expect. System settings will affect score.
