[SOLVED] Low CPU scores in Cinebench ?
shmuel1614
78
Hi.
my Ryzen 5 7600x gets a really low score (826 pts) on Cinebench test after tweaking some settings in the BIOS. Every place online says my CPU should score around 15000.
Here are the stats post benchmark: https://prnt.sc/X2bFPdT9ScsZ
Tweaks:
CPU Core 47.00
100Mhz boost
CPU throttle limit 83c
All curve sign: Negative
Curve optimizer magnitude: 30
PPT Limit: 85000
TDC Limit: 480000
EDC Limit: 640000
Specs:
CPU: Ryzen 5 7600x
CPU cooler: Noctua NH-U12A
Motherboard: B650M GAMING X AX
Ram: Corsair Vengeance 32GB 5200Mhz with XMP
SSD/HDD: Samsung 970 EVO+ 1TB
GPU: RTX 3070
PSU: Thermaltake toughpower GF1 750W
Hi.
Are you sure that you are comparing same versions?
They had huge changes in how they score from one version to an other.
I've installed the latest version on their website, the Cinebench 2024 so no idea.
Edit: ya I just checked, you're right, thanks. 7600x shows score of 921 and I got scored 826, should I be worried?
You can try again but close all open software before doing it and don't do anything not even move your mouse.
Don't forget that review sites test on a fresh install with nothing else running, if you have stuff in the background your score will differ.
