Low fps cuz heat?
simon22
Commendable
Jun 26, 2016
5
Hello,ive got gigabyte gtx 970,i7 6700,16gb ram,everything was fine while playing,but when in my country it start beying 35C outside,then my CPU and GPU start having 70+C,i used to play witcher 3 on ultra on 70 fps,now its 45,it happend of heat or its something wrong with pc?
monitor temps while playing with msi afterburner
if the cpu gets too hot your fps will drop, yes
ok thanks ive start getting worried 😀 its 75C so yea its too high
keep an eye on cpu temps while you play, you really dont want to go higher than 80 degrees
70 degrees while under full load for a video card is cool
for me is 70 high,my pc is 2 months old,normal temp while normal weather was 35 max,and it never goes over 80 thankfully
you said you went from 70 fps to 45
did you turn on hairworks or super resolution?
turn up anti aliasing settings?
