ehertel :
Okay, my next question is. If I upgrade the cpu. Does anyone know a cpu that works good with a NVidia gtx 750 ti. That is compatible with a MS 7374 MSI motherboard
that mobo is am2+ socket right? cant really tell a good processor with that socket, its getting aging, i personally recommend you getting new processor with different socket. i think the cpu is kinda bottlenecking and if you want to get new processor with same socket, performance you get wouldnt be really far from current performance you get, mainly because it is aging. maybe some budget friendly pentium would be pretty good or consider another amd processor with different socket, it might do good job for some casual gaming
