Much lower FPS then i should be getting.
I finished building my desktop a few months ago, parts are listed below. all brand new parts minus the GPU that my friend sent me just so i could save some money. The issue is that from everything i read and when i check the "Can i run it" test i should be able to run most games on high and maintain 60 fps. But for the most part I can barely run any game on the lowest settings.
GTX GeForce 970 4gb VRAM
I-5 8600k @ 3.60HZ
16gb ddr4
My power supply is plenty sufficient
Fallout 4 - 30-35fps on lowest settings
Pubg - 25-30 on lowest settings
I have used DDU as well as reinstalling any of the games in question. Checked all appropriate options (Vsync, power distribution, background processes) but nothing seems to change. Weirdly enough it doesn't matter if im running the game at ultra or lowest settings. still maintain the same low frame count.
I've downloaded MSI afterburner and everything seems normal from what i can tell. Kinda at a loss for why im not getting the kind of performance out of this GPU that others seem to have. Any help would be greatly appreciated! Thanks!
I-5 8600k @ 3.60HZ
16gb ddr4
