Low FPS in CS:GO with Gigabyte GeForce® GTX 1050 Ti Windforce OC 4G
JanusChr
Hey, i upgraded from a GTX 760 because of low fps, but now i have this 1050 TI but im still stuck at around 80-110 FPS :/
I tried reinstalling drivers, making sure drivers are up to date and so on, but didnt find any fix...
Specs: (If you need more just tell me :)
CPU: Intel i7-4770K
RAM: G.Skill Ripjaws Gaming 2133 MHz 2x4GB
Motherboard: MSI Z87-G43 GAMING Killer NIC Military Class III
GPU: Gigabyte GeForce® GTX 1050 Ti Windforce OC 4G
Hope you can help :)
Kind regards
so 80-110FPS is no good?
go to nvidia control panel and look for "manage 3D setting" section. then you will see two tab: global setting and program setting
changes in global setting will affect all games while the program setting tab will affect game by individual basis. pick your choice. then look for "power management mode" and from the drop down menu instead of "optimal power" (which is default) choose "prefer maximum performance".
I don't see the problem..you're getting 80-110FPS, that's an incredible Frame count, even if it's CS:GO.
