Hey, I have a Ryzen 5 1600, RX 570 8GB setup, and I'm getting about 40-150 FPS on ALL low settings (1080p) 16:9 in CS:GO. I've seen videos with the same setup on CS and they're getting like 200-350 FPS. Any idea on how to up these frames? RAM is set to 2666mhz cause I've heard if you set it above 2933mhz on 1st gen Ryzen then your CPU doesn't do very well and I don't wanna have to deal with more issues. Could that be the issue? Rest of specs: ASRock B450M pro4 Motherboard, 16GB Corsair Vengeance LPX DDR4 3600 CL18 (It was $1 more than the 3200 speed in November so I just grabbed it for the future even though my setup isn't good enough for 3600 speed), 512GB Sabrent Rocket NVME SSD, 500W EVGA BQ Power supply.
Thank you all in advance!
