Low fps on bf1
Apr 6, 2018
I bought a great gaming pc a month ago. I was very happy with it.
But when i tried to play Battlefield 1 on it i had very low fps. I tried changing graphic settings to low and i even searched for videos to increase fps. What makes things even more strange is that i have a very old monitor (1280x1024 75hz). And even with that low of a resolution i struggle to get even 60fps on low/med settings.
The guy in this video has the same specs as me but is getting a much higher fps than me
link: https://www.youtube.com/watch?v=Gi47LFXXTpw
The specs of my pc are:
Graphics card: Asus GTX 960 STRIX 2GB
Proccesor: I5 3470 quad-core (3.20GHZ)
RAM: Corsair vengeance 8GB DDR3 RAM (1X8)
HDD/SSD's: 1TB HDD & Samsung EVO 840 120GB SSD
Case: Sharkoon VG-4W
Motherboard: Asrock H61M-GS.
OS: Windows 10 64bit
Does anyone know the cause of this?
If you don't get those frames, scan your PC for viruses, use Malwarebytes free. Also we don't care about your case in this "case", but your PSU is very relevant, tho you would've seen issues with other games also if it were the case, unless you only play lower quality games besides this one. Update your drivers for everything, from motherboard to GPU, unless you've already downloaded those from your manufacturer's page (they don't usually make updates for motherboards so often)
Not running dual channel ram and the GPU is lower end, CPU could be more powerful also, and I7 is really needed.
Really need an upgrade, CPU, RAM and GPU.
MINIMUM SPECS
OS: 64-bit Windows 7, Windows 8.1 and Windows 10
Processor (AMD): AMD FX-6350
Processor (Intel): Core i5 6600K
Memory: 8GB RAM
Graphics card (AMD): AMD Radeon™ HD 7850 2GB
Graphics card (NVIDIA): nVidia GeForce® GTX 660 2GB
DirectX: 11.0 Compatible video card or equivalent
Online Connection Requirements: 512 KBPS or faster Internet connection
Hard-drive space: 50GB
RECOMMENDED SPECS
OS: 64-bit Windows 10 or later
Processor (AMD): AMD FX 8350 Wraith
Processor (Intel): Intel Core i7 4790 or equivalent
Memory: 16GB RAM
Graphics card (AMD): AMD Radeon™ RX 480 4GB
Graphics card (NVIDIA): NVIDIA GeForce® GTX 1060 3GB
DirectX: 11.1 Compatible video card or equivalent
Available Disk Space: 50GB
