Question Low FPS Overnight.
Sharkyzane231
6
AMD 5800x3D
EVGA 3070ti
16GB 3000Mhz (XMP enabled)
3440x1440 144hz (Dell S3422DWG)
CPU temps: 40 degrees C idle, 80 degrees C when gaming
CPU usage: 13% idle, 40% when gaming (though CS uses like 10% and doesn't want to use more)
Just a couple weeks ago my PC was running perfectly fine, consistent 300fps in CSGO, easy 144fps in Fortnite medium settings.
Just recently, all this performance has tanked and now both Fortnite and CS struggle to reach over 100fps on the lowest settings (Performance mode on in FN)
I've uninstalled and reinstalled my graphics drivers, chipset drivers and even reset my bios to factory settings with no change in performance.
I've also reseated all of my components in my PC.
After doing so, I ran a userbenchmark to diagnose any issues. These are the results: https://www.userbenchmark.com/UserRun/62103755
If I could get any troubleshooting tips, that would be absolutely fantastic.
Thank you all.
