[SOLVED] LOW FPS & USAGE on RX 5700
OneApples
Commendable
Mar 9, 2019
28
8
1,565
Hello everyone,
I get lower FPS than expected with my new (used) RX 5700. It is a blower design but temps are fine maxing at 70c.
My Full setup:
MSI B450 Gaming Plus Max
R5 1600 AF
Some Bequiet 630Watt Gold PSU
MSI RX 5700
2x8 GB 3200 CL14 G.Skill
The Problem im having is that I get FPS sometimes beneath 50-40 in games that should run 100+ like GTA 5.
GTA 5 With maxed settings runs at 70 fps, and drops to 40 when in a town etc.
Mordhau runs at 70 but sometimes randomly drops to 50
All while the GPU is at around 70% Usage, in GTA sometimes only 30%.
I know the 5700 can bottleneck the 1600af a bit, but I don't think it should be this big.
The card runs at the specified clockspeeds of around 1700mhz, sometimes 1500 but I think thats just normal fluctuation.
So all in all the GPU runs at too low usage with unacceptable framesrates.
Yes; I have tried DDUing the drivers, Installing chipset drivers, playing with AMD sensitive Settings in the game options etc.
Anyone know how I can push my card?
Thanks in advance.
Another edit: While playing mordhau, at 40fps the GPU sits at 63 Degrees and 1200MHz, this is a joke, it should be at 1700Mhz or something.
I have everything unlocked, no frame cap in place.
Just adding stuff that might be of importance:
My CPU is heavily undervolted at -.135mv, this was surprising me at first, but It has been stable for 2 months now without performance loss.
Im using the Wraith stealth cooler because my 120 aio pump broke just yesterday, cpu clocks at 3.5ghz
