Low FPS with i5-6500 3.20 GHz and Nvidia 1070 GTX 8 GB
Oct 21, 2018
36
CPU: i5-6500 3.20 GHz
GPU: Nvidia 1070 GTX 8 GB
RAM: 16 GB DDR4
SSD: KINGSTON SSDNow UV400 240GB
HDD: Seagate Barracuda 1 TB
Mobo: B150 Pro Gaming
Power Supply: Fortron Hyper S 500 - 500 W
Store page: https://www.alza.sk/EN/alza-gamebox-neo-gtx1070-d4304764.htm
Hi there! Im so glad that I found this website, my problem is in low FPS in strategy games, city building games and so on. Like Cities: Skylines, Hearts of Iron IV, The Guild 3, Transport Fewer, so on. GPU looks fine, Im worried that my CPU is killing the FPS, can you please help me to find some solution? Of course I using newest graphic drivers and performance is set to high. Thanks.
Then nothing to indicate the cpu is limiting performance. Using something like msiafterburner can you see any hardware running very high usage?
What fps are you getting and in what games?
Cities: Skylines at larger cities 20-40 fps
The Guild 3 15-30 fps
Transport fewer 25-45 fps
AC: Origins 10-25 fps
I have no idea why CPU dont go up to 99% if the game needs more calculations.
Which connector on the back of your machine is being connected to the monitor? The thing is if you are connected to the integrated IGPU connector, then you are NOT even using the the GTX1070, and would easily explain the low FPS.
The stronger CPU like the 7700K vs a 6600 is not going to make up the drastic low FPS you are talking about.
You want to identify configuration problems, setup problems, before jumping to replacing hardware.
Now that we know you are connected to the DVI port from the GPU, one of the next thing to check is your drivers. Are you running with nVidia's drivers or are you stuck using some random default drivers that is not actually making use of your video card.
Another thing to check is to verify that you have actual PCI-E power lines feeding your GTX1070. Missing either one of these will lead to bad results.
PCIe power refers to the power connections going from your PSU to your GPU (powering the video card).
The CPU discussion earlier was about system balance. This one is out of balance and will contribute to overall performance.
I agree with nobspls that a CPU upgrade will not resolve the entire issue. Seems there is something else holding back system performance.
Has this system been fully scanned for malware/viruses lately?
