Low FPS with i5-6500 3.20 GHz and Nvidia 1070 GTX 8 GB
Oct 21, 2018
36
CPU: i5-6500 3.20 GHz
GPU: Nvidia 1070 GTX 8 GB
RAM: 16 GB DDR4
SSD: KINGSTON SSDNow UV400 240GB
HDD: Seagate Barracuda 1 TB
Mobo: B150 Pro Gaming
Power Supply: Fortron Hyper S 500 - 500 W
Store page: https://www.alza.sk/EN/alza-gamebox-neo-gtx1070-d4304764.htm
Hi there! Im so glad that I found this website, my problem is in low FPS in strategy games, city building games and so on. Like Cities: Skylines, Hearts of Iron IV, The Guild 3, Transport Fewer, so on. GPU looks fine, Im worried that my CPU is killing the FPS, can you please help me to find some solution? Of course I using newest graphic drivers and performance is set to high. Thanks.
I would reinstall windows, go a clean install with the bare minimum of drivers. You want to rule out problems due to a bad windows install.
If you run the same screwed up install even with a new CPU, you would most likely get the same bad results.
Can you provide support data to show that? Because you would not be here asking for help if everything is working good right?
BTW can you run a bench of your system here, and provide us the link to the results?
https://www.userbenchmark.com/
And for comparison you can see my GTX1070 with my old 2600K here:
https://www.userbenchmark.com/UserRun/1635135
I hoping something will jump out when we see some data.
Could you please game for like 10 minutes while havin MSIAfterburner in the background?
I am curious if your GPU is even boosting to its usual operating speed.
Iave heared that every now and then the gpu runs in "safe mode" with only 300 to 450mhz instead of 1600mhz+
Could be the problem here. MSIAFterburner Screenshot would be nice after 10-15 minutes of gaming.
Seems we are where we started. The relatively slow memory and multi-core performance are not significant (from the benchmark report above). This behaves much like a heat/power issue over time. This is also the relative performance of the CPU versus the potential of the GPU.
It is time to consider upgrade hardware options, or living with the level of performance (overall) being delivered....which isn't bad as measured above.
This should certainly be done.
Health... capacity or life remaining? This is what, 3 years old? If that’s life remaining theres a problem with something doing an insane number of drive writes.
Edit: also not sure about the quality of that psu. It can affect gpu performance.
Agree with everyone else - would reinstall Win from scratch. Preloaded os with bloatware is a bad thing.
Life remaining, I kinda used it for downloading, stored there music and stuff, so its my fault. Its about 3 years old and about the Windows install... Well, I will be forced to do it, when my SSD dies. I will wait till the end and then I will buy new SSD and install there new W10. I tried to migrate my OS from SSD to HDD, but sadly I dont found a way without erasing HDD content :/
Anyway, do someone know how to find information about my power supply? I considering few upgrades, but I need to know if my power supply can handle it. I know that its Fortron Hyper S 500 - 500 W, but I would preffer something that says current W usage.
