Hello, can someone help me? For the past 2 weeks I've been having fps issue with this system. The system is a mix and match of old parts from my brother's pc
PC Spec
CPU: Core i5-6600 (used)
GPU: ZOTAC GTX 1060 3GB (used)
MOBO: Biostar H110Mhv3 (used)
RAM: 12GB DDR3 1600MHZ (Dual Channel) (New)
PSU: CM MasterWatt Lite 600W (New)
The monitor that I used is a LG with a resolution of 1440x900 (used a vga to dvi adapter to connect the monitor lol) .
(The screenshot was taken from a bot match)
When playing dota2 in intensive part, the gpu usage is around 25% to 35% at 1596MHZ core clock, while the cpu clocked at 3.5GHZ at 80% to 95% usage with 44fps.
The setting that i use
While at the menu, the gpu usage is higher at 55% to 75% usage at 1569MHZ core clock, while the cpu is at 40% to 50% usage and clocked at 3.7GHZ with 100+fps.
Can someone explain and come up with a solution , It's very confusing. or the system is being bottleneck but the cpu?
Thank you.
Note: I tried running various api (dx9, dx11, vulkan, and opengl) but the result is still the same. i'm also using the latest nvidia drivers
PC Spec
Thank you.
