Low FPS !!
excelat
7
I am a CSGO player . When my comp was new i used to get 100+ fps, which soon dropped to 60. Now from the past few weeks i get 30 fps on average . M friends tell me i should get fps above 250-300 as i have a i5 +3450 @ 3.10GHz .
My computer specs.
Intel i5 +3450 @ 3.10GHz .
Intel corporation DH61WW
Nvidia XFX geforce GT 630 2GB graphics card
8GB KINGSTON RAM
256 V psu
Please give me some solutions , if he problem cant be resolved then suggest me a nice mobo and also tell me if i should go for GTX 760 2gb 256-bit or Sapphire 7950 3gb 384-bit
PLEASE help . Thanks.
Your GPU sucks. Go for either the 760 or the 7950 and you will have more FPS than you could hope to use in CS:GO
The 760 is a really solid card for the money right now.
You will need a good PSU too - I recommend a 650W seasonic or xfx.
Thanks for the info , i have heard that corsair provides better psu than seasonic . Is it true ?
And can u please tell me a good mobo ! i cant reallly pick 1 .
Is this the wattage or did you make a mistake? Give the max. wattage and the amps on the +12voltrail(s) or just the type and model+wattage.There is a sticker on the side of the psu which will tell you these things.
With no upgrade to the psu could you probably get away with the gtx 750 ti.
Haha, well to start corsair doesn't make PSUs. The best corsairs, such as the expensive AX series, are made by seasonic.
Your motherboard is fine, why would you upgrade? If you really want to upgrade I'll make you a recommendation, but I doubt you will notice much performance gains.
ok thanks for the info , if it wont make any performance change then i will avoid it 😀
ok thanks , but i heard that windforce cooler is the best . Is it true ? then i shoud go for windforce
Sounds like a plan. In reality the 550 watt xfx made by seasonic is plenty for that system, but I recommend the 650 only for ability to upgrade in the future.
You can pick up the 550 if you want for around 50$, it's a good choice. If you don't plan to get a high end GPU in the future just do that
actually i just bought it on flipkart ( a indian megastore ) for like 146 $ , it has 7 years warranty . If i have to change the graphics card i would do so only after 3 years or so . So thanks
