Question Low GPU and CPU usage on ROBLOX
Dec 26, 2022
When i play ROBLOX, i have 150-170 fps on low settings, but i get the same framerate on max, i went to check task manager and the CPU and the GPU were under 20%, when i put the game on max settings, GPU usage went to 60%+ but CPU usage was low, I am on a laptop and here is my specs
CPU: Intel Core i5-11400H 6 Core
GPU: GeForce RTX 3050 Ti Laptop GPU
Memory: 16gb DDR4 3200mhz (2x8gb)
Laptop display: 1920x1080 144hz
All other games have high usage up to 95+% and higher
You assume that those ppl are using the same mods and same power limits and haven't overclocked both cpu and igpu etc. It's also possible to get your exact laptop model with different cpus and gpus etc so may not be an entirely fair comparison.
If your laptop model has a gpu additionally, it may not be active, you may be using the igpu, depending on the power and/or app settings. Most gpus are preset only to use the gpu during 3D, resorting to energy saving igpu for 2D apps.
Online videos only show what is Possible, not what is Probable, and the Possibilities are generally tweaked for maximum performance, whereas your Probability isn't.
Reactions: Roland Of Gilead
