Low GPU & CPU utilization leading to very low performance?
BlueMihai
194
I just finished my new secondary build, but I am experiencing awful performance almost on any game. My fps in games is incredibly low comparing to what I should be getting. The CPU load and GPU load never go even near 100% and just stay near something like 50% most of the time, I have 16gb of ram so that shouldn´t be an issue either.
Below are some screenshots displaying the CPU and GPU usage + FPS
Vsync is disabled in all of them, and the temperatures were fine aswell so the PC was not throttling.
  • Star Wars: Battlefront screens here.
    Battlefield 4 screens here.
    Alien Isolation screens here.
    CSGO screens here.
    GTA V screens here.
    Space engineers screens here.
    League of Legends I do not have screens of, but it was running 44-120fps.
    I have no idea why, but this PC was getting better fps on LoL with am AMD HD 4560
System specs:
CPU (s) = 2x Xeon 5355x
GPU = Gainward Phantom 780 Ti
RAM = 16GB DDR2 ECC
MOBO = 0DT031
PSU = 750W (the one that comes with Dell Precision 490)
Storage = SSD + 1.5TB HDD
OS = Windows 8.1 Pro
System Specs from Aida64:
Field Value
Computer
Computer Type ACPI x64-based PC
Operating System Microsoft Windows 8.1 Professional
OS Service Pack [ TRIAL VERSION ]
Internet Explorer 11.0.9600.18125
DirectX DirectX 11.2
Computer Name TOUR
User Name MixU
Logon Domain [ TRIAL VERSION ]
Date / Time 2015-12-30 / 18:54
Motherboard
CPU Type 2x QuadCore Intel Xeon X5355, 2666 MHz (8 x 333)
Motherboard Name Dell Precision WorkStation 490
Motherboard Chipset Intel Greencreek 5000X
System Memory [ TRIAL VERSION ]
DIMM-A1: Kingston KINGSTON 4 GB DDR2-667 ECC DDR2 SDRAM FB-DIMM (3-3-3-9 @ 200 MHz) (4-4-4-12 @ 266 MHz) (5-5-5-15 @ 333 MHz)
DIMM-B1: Kingston KINGSTON 4 GB DDR2-667 ECC DDR2 SDRAM FB-DIMM (3-3-3-9 @ 200 MHz) (4-4-4-12 @ 266 MHz) (5-5-5-15 @ 333 MHz)
DIMM-C1: Kingston KINGSTON 4 GB DDR2-667 ECC DDR2 SDRAM FB-DIMM (3-3-3-9 @ 200 MHz) (4-4-4-12 @ 266 MHz) (5-5-5-15 @ 333 MHz)
DIMM-D1: Kingston KINGSTON 4 GB DDR2-667 ECC DDR2 SDRAM FB-DIMM (3-3-3-9 @ 200 MHz) (4-4-4-12 @ 266 MHz) (5-5-5-15 @ 333 MHz)
BIOS Type Phoenix (04/25/08)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM2)
Communication Port ECP Printer Port (LPT1)
Display
Video Adapter NVIDIA GeForce GTX 780 Ti (3 GB)
3D Accelerator nVIDIA GeForce GTX 780 Ti
Monitor Asus VS248 [24" LCD] (D9LMQS107333)
Multimedia
Audio Adapter nVIDIA HDMI/DP @ nVIDIA GK110 - High Definition Audio Controller
Audio Adapter SigmaTel STAC9200 @ Intel 631xESB/6321ESB - High Definition Audio Controller
Storage
IDE Controller Standard Dual Channel PCI IDE Controller
IDE Controller Standard SATA AHCI Controller
Storage Controller Microsoft Storage Spaces Controller
Disk Drive SanDisk SDSSDX240GG25 (240 GB, SATA-III)
Disk Drive WDC WD15EARS-00MVWB0 (1500 GB, SATA-II)
SMART Hard Disks Status OK
Partitions
C: (NTFS) [ TRIAL VERSION ]
D: (NTFS) 1397.3 GB (1270.9 GB free)
Total Size [ TRIAL VERSION ]
Input
Keyboard HID Keyboard Device
Mouse HID-compliant mouse
Network
Primary IP Address [ TRIAL VERSION ]
Primary MAC Address 00-18-8B-15-8D-1A
Network Adapter Broadcom NetXtreme 57xx Gigabit Controller (192. [ TRIAL VERSION ])
Network Adapter TunnelBear Adapter V9
Peripherals
Printer Fax
Printer Microsoft XPS Document Writer
USB1 Controller Intel 631xESB/6321ESB - USB Universal Host Controller
USB2 Controller Intel 631xESB/6321ESB - USB2 Enhanced Host Controller
USB Device Razer Mamba
USB Device USB Composite Device
USB Device USB Input Device
DMI
DMI BIOS Vendor Dell Inc.
DMI BIOS Version A08
DMI System Manufacturer Dell Inc.
DMI System Product Precision WorkStation 490
DMI System Version
DMI System Serial Number [ TRIAL VERSION ]
DMI System UUID [ TRIAL VERSION ]
DMI Motherboard Manufacturer Dell Inc.
DMI Motherboard Product 0DT031
DMI Motherboard Version A00
DMI Motherboard Serial Number [ TRIAL VERSION ]
DMI Chassis Manufacturer Dell Inc.
DMI Chassis Version
DMI Chassis Serial Number [ TRIAL VERSION ]
DMI Chassis Asset Tag [ TRIAL VERSION ]
DMI Chassis Type Tower
I know that my SSD is being bottlenecked by the SATA II limits, but it is better than having the SSD just gather dust on my shelf :). Also, the PCI-E lane is 16x gen 1, which should not be a problem either. Linus (LinusTechTips) did something similar to this and he had very similar (yet weaker) CPU´s and a 4x Pci-e Lane, and his results were wayyy better than mine. He was getting playable framerates unlike me --> something is wrong with my PC🙁
ADDED INFO:
-Pictures of BIOS tabs and options are here. Don´t worry they are in a logical order :)
-RAM is 4 × Kingston 4Gt 667MHz ECC (KFJ-BX667K2/8G), and is running at 667Mhz, according to BIOS and every other program besides CPU-Z :)
-GPU gets its power through 2 adaptors, one is a "2x molex --> 8 pin" and the other one is a "6 pin --> 8 pin"
Stuff I have done so far:
-Set Power Options --> High performance (also changed PCI-E link State Power Management to ´off´)
-Enabled FSB Optimizations from the BIOS settings.
-Set the gpu to maximum performance from Nvidia control panel
-Tried setting the game(s) to run on "high priority" from task manager
-Disabled any overlays to see if they had a negative influence on the performance(such as Origin, steam, and RTTS overlays.)
-Running games in fullscreen instead of borderless.
-Set GPU to Prefer Maximum Performance from Nvidia control panel.
-Enabled Threaded Optimizations from Nvidia control panel.
-Uninstalled Antivirus (Kaspersky)
Well I bought the Dell 490, replaced the processors (It had 2 5050´s) and got 16gb of ram for it (it had none in the beginning). I am also using the original case and PSU at the moment, I might change the case later, but I don´t think that getting a new PSU is even an option :)
Sorry I thought it was the drivers page(EXE file)
Those are the INF files which you can manually install in
Windows/System32/INF.folder
But if it is working fine for you then not necessary.
I had not forgotten about your thread.
My Daughter, her husband and the grand-kids were up for the holidays, so I have not had a lot of free computer time this last week.
Wound up playing Starcraft2 with the grandson until 1:00 am last night.
But sadly they had to drive back to south Florida today.
Sounds like you had fun ^^
Anyways, I installed the ´chipset drivers´ but I am not sure if I installed the correct storage drivers, I installed the ´Intel Matrix Storage Manager´ since the others said ´raid´and I am not using raid. But with these installed, I still didn´t notice any difference in the performance :/ . I tested this on Space Engineers and Battlefront.
Going to test this system with 2 PSUs just incase the CPU´s aren´t getting enough power. I will power the GPU with that, this way the CPU´s have a ridicilous 750 watts or so to use.
This is pretty much the last idea that I have 🙁 I have almost given up on this system.
Tried the system using a 760w psu to power just the GPU, leaving the 750w psu to power the CPU´s. Using 2psus had no effect on the performance, so the voltage was not the cause to this problem.
Did some more digging.
It appears that the latest operating system supporting the x5000 chipset was vista and 7 with vista drivers.
But you can run windows 7 with vista drivers for the chipset and get good performance.
The generic drivers by Microsoft work .
But they are not chipset optimized for performance.
You need win 7 on your hardware for driver support
I run Lubuntu on mine for fulding@home. So I never encountered the windows driver problem.
I installed XP pro on it a couple years back for overclocking, monitoring and testing. Then Installed Lubuntu for F@H production, which is faster than windows production from OS overhead.
Edit.
There are some post on google about modified INF files for drivers. which work.
You can find these in google if you are set on win8 for OS.
I will not link to something I have not tried myself.
Hello, i see that you set the power settings to high performance, but you also set cpu min and max to 100%. It seems obvious and simple, but sometimes we forget the obvious things.
Yep, I messed around with those aswell, I even tried the "core unparker" method.
