Question Low gpu power
Jul 7, 2023
8
My max watt 164. How can I fix this other users have 1925 mhz and 220 watt.I'm having a low power usage issue in games.Gpu powers always %59 .Even in a stress test
Ther users have 220 watts of power draw.My card max using150 watts.I haven't cleaned for a long time.My gpu GİGABYTE RTX 3070 GAMİNG OC CPU:Ryzen 5 5600x
This is my log when I playing RDR2
LOG
Jul 7, 2023
8
MOTHERBOARD:GİGABYTE B550M DS3H
RAM:corsair vengeance 16gb ddr4 3600mhz x2
SSD:KİNGSTON FURRY RENEGADE
GPU:RTX 3070 GİGABYTE GAMİNG OC
CPU:RYZEN 5600X
PSU: DEEPCOOL PF750 750W
OS:WİNDOWS 10
What's your budget for the PSU ? Where are you located, Turkey ? Get any decent quality unit from the likes of Corsair, Be Quiet, EVGA, Cooler Master, Antec and others. There are many more brands though.
This list is not 100% accurate or up-to-date, but here are some power supply brands and their respective Models by popularity and ratings.
SEASONIC PRIME, and Prime Ultra, or FOCUS Plus GOLD, Focus Plus Platinum.
CORSAIR AXi, RMi, RMx 550/650W, SF, HX 2017, HXi.
FSP - Hydro PTM 550/650W.
Cooler Master - MasterWatt Maker MiJ, V series 550/650W.
Antec - High Current Pro, High Current Platinum, Earthwatts Pro Gold, HCG Gold.
Super Flower - Leadex Gold II.
be Quiet! - Dark Power Pro 11, Straight Power 11, Dark Power Pro P10.
EVGA -Supernova G1+, GQ, P2, T2, G2, B2, BQ =>750.
While I don't disagree that you should change PSU the one you have shouldn't have problems powering your system. Are you using a daisy chained power connector to hook up the power to the card or are you using the two separate cables? If you are using daisy chained switch it to the two separate cables as this is the only thing I can think of you could do before replacing the PSU.
