[SOLVED] Low performance and score with decent system, No idea what's Happening!
Apr 23, 2022
Hey all, I've got a system that's not too old (~a year or two) and it seems to be performing extraordinarily poorly... (Some game bog into 40-50 fps on 1080 with med settings) I did notice my GPU seems to run a bit warm, and scores extremely low on benchmarking, but I have no idea how to fix it! Ideas?
Specs:
Operating System
Windows 10 Home 64-bit
CPU
AMD Ryzen 7 2700X 60 °C
Pinnacle Ridge 12nm Technology
RAM
32.0GB Dual-Channel Unknown @ 1599MHz (18-20-20-38)
Motherboard
MSI B350M GAMING PRO (MS-7A39) (AM4) 45 °C
Graphics
LG Ultra HD (1920x1080@60Hz)
DELL SE198WFP (1440x900@60Hz)
DELL S2719H (1920x1080@60Hz)
4095MB NVIDIA GeForce RTX 2080 (Gigabyte) 58 °C
Storage
447GB SATA SSD (SATA (SSD)) 33 °C
931GB TOSHIBA DT01ACA100 (SATA ) 38 °C
1863GB Samsung SSD 870 QVO 2TB (SATA (SSD)) 40 °C
223GB KINGSTON SQ500S37240G (SATA-2 (SSD)) 36 °C
Optical Drives
No optical disk drives detected
Audio
Logitech G533 Gaming Headset
PSU is Corsair CX750M
3DMark Benchmark: https://www.3dmark.com/spy/26445934
that's a fairly low rated power supply.
it could be an issue by not providing stable power when the graphics card most needs it.
AMD Ryzen 7 2700X
it's also possible that your 3200MHz RAM is holding back the possible performance of the Ryzen 7 CPU which will then be feeding less frames per second to the GPU.
are these temperatures you have included idle, average, or max temps?
what games exactly?
AMD Ryzen 7 2700X
what games exactly?
what games exactly?
I Included Idle Temps, but the 3DMark run is showing 86C avg for GPU and 80C avg for CPU
The Games giving me issues are:
War Thunder
Final Fantasy 14
Forza Horizon 5
Heroes of the Storm
Sea of Thieves
Also Star Citizen, but I know that's kid of a low frame expectation for anything right now.
those are very high for idle temperatures.
for a well designed desktop system i would expect half of those posted for CPU & GPU.
it's very possible that you are experiencing thermal throttling while playing games.
keep an eye on temps while gaming with an OSD running and see what they are reaching.
what CPU cooler are you using,
what case is the system housed in,
what case fans are you using, where are they positioned, what is their orientation, and how are the fan's RPM being controlled?
