G
Guest
Guest
Hi guys, Thanks for taking the time to read this...
I've been wanting to build a NAS for quite sometime now, and then I saw the MSI H97M ECO motherboard and decided to go for it....This link shows the low power consumption of the motherboard...the power supply used there was a FSP Aurum 92+ 550w PSU which I think is slightly overkill. Should I go for the same power supply or move to a different power suppy?? Any other suggestions?? I was wondering a 60W PicoPSU, but that has only one SATA power output...I also thought of the FSP Aurum 92+ 450w PSU and also the Antec EarthWatts 450w 80+ PSU...I can't seem to find any PSU's rated below 100w....80+ platinum preferred(since this thing will be on 24/7).
I have even considered doing the exact same build mentioned in the above link...I just want to know if I have any better alternatives...PSU's (80+ platinum) suggestions anyone?
I will also be adding 4 x 7200rpm 2TB SATA drives.
Haven't decided on the processor- Probably an i5 though..
Thanks in advance..
Thanks in advance..
