Two days ago, I opened my PC case to do a quick clean and some cable management. I then installed some magnetic dust filters on the outside of the case. I previously had motherboard issues which were resolved buy a professional. One slot will fry any stick of RAM that you put in there, but the other works fine. I hear a loud, low vibration in the case, which is comes and goes. I cracked open the case and determined that it isn't either of the hard drives or the optical drive. Noise or no noise, when I boot it up, I see the Gigabyte Ultra Durable® logo, then it goes to a black screen with a flashing underscore in the top left. Please help!
UPDATE- The vibration is definitely from the power supply, as when I whack the **** out of it, it shuts up. HOWEVER, the black screen remains when I try to boot from my regular boot drive. I booted from a USB stick of Windows 10, but there is no option to run the OS right from the drive without using it's install tool.
