[SOLVED] Low voltage
Jan 31, 2020
Is it normal that I can run a stable clock of 4.0 GHz with a voltage of 1.2 volts on a Ryzen 5 2600x? I am currently overclocking in Ryzen Master because my BIOS won't change the clock for some reason, and I my temps are a few degrees below 70 ( like 68 or something like that ). Should I continue lowering the voltage until I get an unstable clock?
