Lowest 980ti build as possible
lolmaxgg
18
Is this pc build good to go? New to pc gaming community.
Processor : Intel i5 4690 (non-k version)
Motherboard : AsRock H97M PRO4
RAM : Avexir white 2x4GB 1600mhz
HDD : WD 1TB Caviar Blue
Graphic Card : GTX980TI Reference
Power Supply : CM V650 (80+ GOLD)
Casing : Aerocool xpredator x1
Keyboard Mouse : CM Devastator
Extra Fans : NZXT FN120 V2 x2
CPU Coolers : Scythe Katana 4
Any suggestion is welcomed. (Try to be as low cost as possible)
Will cpu bottleneck 980 ti?
Can the psu handle 980 ti?
thx
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($176.98 @ NCIX US)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($69.89 @ OutletPC)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Newegg)
Video Card: EVGA GeForce GTX 980 Ti 6GB Video Card ($649.99 @ B&H)
Case: Corsair 300R ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($54.99 @ NCIX US)
Total: $1101.82
Generated by PCPartPicker 2015-06-17 13:43 EDT-0400
Won't tht cpu bottleneck the 980ti? #4460insteadof4590
What if I swap it with CM G750M (80+ Bronze)? Is it reliable too for 980 ti?
So is my build good to go? I'm waiting for experts like you guys to approve this pc build. thx
The EVGA B2 750w is by far the best deal on psus in the 550-750w range.
The 4590 is $12 more than the 4460. It's 300mhz faster. That's a toss up. Either would be fine.
Using a locked i5, there would be zero performance difference between the Anniversary and the Pro4. The Pro4 offers no meaningful features that the Anniversary lacks.
Definitely has meaningful features lad. Extra PCIE Slots and what not can definitely be meaningful. Let it be a sound card or something else.
Also, the difference between the 4460 and 4590 is even smaller. 100 Mhz instead of 300 Mhz.
I would consider the B85 Pro4 if the H97 Pro4 is no option. It's also better.
http://www.asrock.com/mb/compare.asp?SelectedModel=H97M+Pro4&SelectedModel=H97M+Anniversary
Are these features necessary?
ASRock Super Alloy
- Premium Alloy Choke (Reduces 70% core loss compared to iron powder choke)
- NexFET™ MOSFET
- Sapphire Black PCB
Look, can you spend 1200 dollars? Because with only an additional 50 dollars comes excellent components in return. An i5-4690k with a Z97 motherboard and a nice case.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.99 @ SuperBiiz)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard ($91.55 @ B&H)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($52.99 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case ($54.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($75.98 @ Newegg)
Total: $1195.48
Generated by PCPartPicker 2015-06-17 14:51 EDT-0400
I would advice this build. Overclock is going to come in handy with the GTX 980 Ti in games like Battlefield 4.
I really like your build too. But just kind of worried that the 980ti will be underutilized. And also what's your opinion if I swap that psu with CM G750M 750watt psu?
i5 4460 - 3.2ghz base, 3.4ghz turbo
i5 4590 - 3.3ghz base, 3.7ghz turbo
The H97 Anniversary is fine. If you REALLY need to feel like you're getting a better board, get the H97 PERFORMANCE that's a couple $ cheaper than the Pro4 and is actually a better board.
My problem is that in my country the retailer shop only gives me 2 mobo options one is Asrock motherboards and the other is Asus. Your build is just almost $100 more compared to his.
In my country the cost of this build is already $1600.
Processor : Intel i5 4690k
Motherboard : AsRock Z97M Anniversary
What about this build guys? Its almost the same price.
Can you explain to me why shouldn't I get the anniversary version better off with H97?? Yes, I can afford the Z97 Pro4.
