Hello all,
I have a laptop that died and before I send it in for repair I would like to backup some things off of the hard drive. I don’t have a desktop computer, only another laptop. I could really use a way to convert the M.2 NVME to USB.
I found an adapter that converts the drive to a 2.5 inch form factor SSD and then an SSD to usb cable but they aren’t compatible because the cable has a gap between the power and data connections but the adapter has a raised section with pins on it instead of a gap.
I would also settle for a USB cable that fits the adapter, but I can’t find that either.
Here’s the adapter I picked up:
Ableconn IU2-M2132 M.2 to U.2 Adapter - Turn M.2 NVMe SSD into 2.5" Drive for U.2 (SFF-8639) Host Interface https://www.amazon.com/dp/B01HR0PKJQ/ref=cm_sw_r_cp_api_b1pJAbP9Z2H01
