This is my first thread on TH so I won’t bore anyone with the life story or rig setup. Just though this was a simple solution to an inherent problem with PCB mounted M.2. This is especially true if you have a graphics card sitting directly over top of the thing (like I do).
Installed it and got it working (google and manufacture manuals are great for this). As expected the temps in static air where horrible. I don’t have a fancy FLIR but when any no-contact thermometer reads 103C on electronics you know you have to fix that.
I peeled the sticker off so I could start getting things done. The controller and the other little chip (I dunno what it is) were a thinner BGA package than the mem. Sooo, I cut some perforated spacer to level up things for the heatsink.
The stuff I used in the previous pic is really meant to be used as is without any kind of adhesive or compound but that didn’t stop me from using any. Ultra-fine copper mesh works just as well, but tends to have stray “fibers” if you’re not careful.
I rummaged around in the bin until I found a piece of heatsink that looked right and cut it to fit (2.75”L x 1”W x .225”H btw). Funny thing is I had gone this far with no thought whatsoever as to how I was going to keep the heatsink in place. A trip to the plumbing section at the hardware store took care of that (O-rings can you believe it? How freaking simple/easy can you get). I just made sure I had one over each chip/section so as not to put undue stress on the rather thin PCB and apply even pressure.
I will note that this heatsink has a non-conductive coating on it so I was not too worried about anything touching. An insulating film could easily be cut to fit if needed.
Can you guess what kind of motherboard I have?
Idle temps where about 38C~40C
Making it hot
Sweet!
Cool (literally compared to 100C+)
And here is the great part. Since PCIE and M.2 are fairly standard this methodology could be applied to any PCB mounted M.2.
I’m sure there is a snazzier way of doing this, but I didn’t want anything to be permanently attached on the off chance I felt like dealing with a warranty claim.
If anyone has a more "professional" and also still non-permanent way of doing this i'm all ears.
Making it hot
Sweet!
