M2N-MX SE PLUS Memory Problems
This solved it for me too! Thanks a ton guys!
CUBANYERO wrote :
I had same problems,the solution is easy.put only 1 module memory ,run bios setup utility/advanced/nortBrige Configuration/memory configuration/bank interleaving / SET (AUTO) /exit & save changes / BINGO ,run perfect , beloved patriot luck
CUBANYERO
i just registered here to thank you my friend!!!! 😀 😀 😀
