M2N68-LA (Narra2) First Time Mod Please Help
toucansam
25
Christmas time is here! And this year I get the old desktop because my dad bought a new one!
Time to upgrade!!.....???
....But it's my first time. It's not that I am in any way tech-impaired. I just want to be sure I'm doing it right and that all my components will work on this mobo.
SO after much research this is what I have:
Base Computer: HP Pavilion a6110n
Link- http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01048277&lc=en&cc=us&dlc=en&product=3436818
Mobo: M2N68-LA (Narra2)
Link- http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01080282&lc=en&cc=ca&dlc=en&product=3436818&lang=en#N453
GPU: Athlon 64 X2 (B) 4400+ 2.3 GHz (65W)
Is this too sub-standard for my upgrades?
What I've decided to upgrade- HDD, Graphics, Memory, Sound Card, PSU
Budget- ~$300 (its low I know….)
Memory: Kingston 2GB KTH-XW4300/2G DDR2-667
Ports on mobo- four 240-pin DDR2 DIMM sockets
Supports PC-4200 (533 MHz), PC2-5300 (667 MHz), and PC-6400 (800 MHz) DDR2 DIMMs
Non-ECC memory only, unbuffered
Link- http://compare.ebay.com/like/221158016948?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y&bigimg=y
Graphics: ASUS ENGTX550 TI DC/DI/1GD5 GeForce GTX 550 Ti
Mobo has one PCIe x16 slot
Link- http://www.newegg.com/Product/Product.aspx?Item=N82E16814121435
HDD: Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Link- http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
PSU: CORSAIR TX Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Compatible with Core i7 Power Supply
Link- http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Sound Card: Vantec 7.1 Channel PCI Sound Card
Link- http://pcsdesign.ca/Products/Vantec-71-Channel-PCI-Sound-Card?m1track=googlebase&gclid=CNG09ZL3q7QCFQ3nnAodWBIACQ#googlebase
Pros Cons? Comments? Suggestions? Praises? Bashes? Noob GTFO? Anything is very much appreciated!
All I'm trying to accomplish here is to get my hands dirty in desktop modding and eventually building. Want to do it right so I'm here for hopefully for some conformation on what my research has given me. Thanks to all.
p.s. here is the guide I’m using-
Link-
http://www.computerworld.com/s/article/9134545/This_old_PC_Revitalizing_an_aging_desktop_computer_on_the_cheap?pageNumber=3
You need to be considered about bus width(memory interface width)
Gt 430 128bit
Hd 4650 128bit
Hd 4850 256bit
Go for hd 4850 it is about $50-$100in ebay(buy it now)? Won't be a problem. Your CPU will drag down it a little bit.
I still have my HD 4850 512mB from Sapphire. I test all games with it. Recently I ran assassins creed 3 at full specs with no lag, no ssd, at 1080 full hd. If I use a ssd it takes on all games at highest specs(Even BF3) if you were wondering.
Thanks alot for the quick reply. Me being a first timer and all I'm still just scratching the surface with all there is to know about graphics cards. It's hard for me to get all the right info for what I'm doing so I really really appreciate you helping me out on this (probably my biggest) dilemma.
how is this?- VisionTek 900181 Radeon HD 2600PRO 512MB 128-bit GDDR2 PCI Express x16 HDCP Ready CrossFireX Support Video Card
Link- http://www.newegg.com/Product/Product.aspx?Item=N82E16814129091
Don't have much experience with nVidia cards but Ati was much better than nVidia. In the article they are talking about a hd 6550 from amd not Ati. AMD has failed to keep up the standards of ATI. Trust me hd 4650 won't be a bad card.
I would have said to get a HD 4850 it is a phenomenal card but your processor may bottleneck it.
Gt 430 128bit
Hd 4650 128bit
Hd 4850 256bit
wow thats awesome. well thanks A TON for the help. really cant thank you enough. i'll post results here probably sometime after x-mas.
Thanks again
