M51AC Asus case for a power supply upgrade and graphic
M05K
708
Hey everyone!
I need help because im upgrading my Desktop soon, so here i go:
This power supply fits in my case? XFX Pro 650W Core Edition
This Graphic card fits in my case? Radeon HD 4870 X2
My case : http://www.asus.com/Desktops/M51AC/
Im more afraid of the Power supply, I dont know if it really fits, the graphic card i think it fits well.
Thank you everyone 😀
That's different,i thought you were buying it.
The r9 270X is about that price,but it depends on the country you live in.Here in Holland i can get a R9 280 for under €200 and by that time maybe even a gtx 760.You probably will have to look at these three by that time.
It is.
Maybe a new case for better ventilation,that card runs hot,but you could first try with your current case.
With going from nvidia to amd will you have to thoroughly get rid of the nvidia drivers before installing the amd ones,with the next two programs should you...
Btw heres my system specs:
Intel® Core™ i5-4430S (6M Cache, up to 3.20 GHz)
6GB DDR3 1600MHz
HD:
1TB SATA 7200 rpm
NVIDIA® GeForce GT625 2GB
Im chaging the Graphic card because this one its not good for gaming, not good really!
So i think the only problem is the graphic card , so that why im upgrading, im correct?
Well bad??? Not per se,but most games support DX11 by now and would give better graphics because of that when run on a DX11 card.
From what i read does for instance watchdogs not run on DX10 cards,altough there seems to be a work around.I had a problem with BF3 with DX10 cards,don't know if that's solved,i just got a DX11 card.
What other options do you have in the same price range?
I want a medium/High graphic card around 200 €/£
From now, i will get that ATI because a person will give it to me so, if you can recomend me a good one i will buy it in the mid of the summer, but for now i will keep that ATI, so a PSU upgrade is good so when i buy the new graphic card it will be better
It is.
With going from nvidia to amd will you have to thoroughly get rid of the nvidia drivers before installing the amd ones,with the next two programs should you be able to do that,
http://www.guru3d.com/files_details/display_driver_uninstaller_download.html
or
http://treexy.com/products/driver-fusion
use these in safe mode for the best results.The first will ask to restart in safe mode for the removal.
I will buy another graphic card later in this summer, i will see the prices, if it is around 200€ i probably will get one but my PCI-E is 2.0 i think.
Btw, like when i play DayZ i get low FPS's i think its due to my graphic card because its not good, my Intel® Core™ i5-4430S (6M Cache, up to 3.20 GHz) its good I think, the only problem in my Desktop its the Graphic Card, i already saw some things on the internet saying GT 625 its like a laptop graphic card in a Desktop.
What do you think? Its really a graphic card problem? That why im upgrading my Desktop, to get better fps's.
That shouldn't give problems with newer 3,0 cards.
I think it is.The hd 4870x2 should be a good improvement.Your cpu is good enougfh for some time,don't worry about that one.
Yea, btw I saw on the internet i can remove the graphic drivers in the windows without any software, but you gave me that softwares so i think its better right? To do it in that way
I wanna thank you again, you're really helping me 😀
That's true,but it would be a good idea to check with the first program to see if there were leftovers.It's still a good idea to do it in safe mode.
And you're welcome.😀
Im sorry Vic, but I cant see where is "ATX" in that page, tried to find out, because I afraid if the PSU doesn't fit there, but you said it will, because i will buy by order not in a local shop
It doesn't literally say that.I look a the case and it's size and say that's an atx case,The psu should fit.
Looked again at different pictures and to me does it look oké.
It's up to you to trust me or not.
You could give me measurements of the psu that is in it.Taken from the side of where you look at it from the back of the case,
height/width/depth.
Im not opening my Desktop right now, only when I have all the equipment because my Desktop is still on warranty, I take the measurements outside of the box and I have the correctly height/width/depth I think, like you said its an ATX box so it should fit correctly.
Btw, I hope the process is like Plug & Play, this is not my first time I change some parts of my desktop, but this time, Im changing it more. Like the PSU , Graphic Card and more RAM.
