Hello, over the past week I've been experiencing a sporadic issue with the Mainboard Fan 3 running slow/noisy after boot up. Shutting down and restarting has cured it so far. It's connected to a Fractal 140mm fan which is attached to a Corsair H90 radiator along with a second 140mm fan(push/pull) all connected to the rear of the case. It's a dip in speed of around 400 rpm. The PSU is a SeaSonic 660 Platinum series.
Is this issue with the fan sound like it's going bad or can it be something else? Also, I've got a Nvidia GeForce GTX 770 2GB GPU.
I look forward you your input. Thanks!!
