OK. I pulled the trigger and bought the Intel 660P m.2 2TB today from tiger direct for $310 (missed the $260 price on newegg and kicking myself). I know its half as fast as the EVO Pro version, but I can't justify that $550 price and I really wanted all my crap on one main drive, so i didnt want to go with smaller EVO pro.. According to the Asus rep, I can run two of those ssd's (m.2 and pcie) but it will only be raid0, which doesn't really sit well with me. From what I read I can still access my current 2tb hdd as a backup drive. I think i can run raid 1,5,10 if I added another HDD, but only in sata and not sure how that works if everything is on the m.2 ssd. My luck, probably not.
QUESTIONS:
Should I just clone the HDD to SDD as is? only 500 GB on there after 2 years of use
Should I do a fresh win7 install on new SSD? (not looking forward to all those updates and haven't had the best luck reusing keys)
Should I partition the new SSD to keep OS and Data separate?
Should I bite the bullet and upgrade to win10 since support effectively ends early 2019? I'm not a fan of getting all of this set up only to have to deal with OS upgrade in a year and redo all my backups.
As my original post indicated, I'm also trying to set up a back up system at the same time too.
Since this post, I uploaded just about all my files to my business onedrive account to sync, desktop, Ipad and phone (I understand this isnt an actual backup, but more for convenience to share among devices.
I connected my unused 4 TB external to my modem/router via USB 2.0, which will serve as backup for my computer and my wife's (She doesn't really save a whole bunch on there). This will take place after new drive is installed. Trying to clean up my data files too.
I plan to use my current 2TB to store a back up of my new SSD. I bought the 3 yr seagate data recovery from the new drive for $22 in case it craps out. I'm also looking at Backblaze backup for the $50/yr. Not sure that I really need both.
I currently only have about 500GB on my HDD with everything on it. I do have a 500GB external with 450 GB of movies/music and some data files on it that will make its way to the 4TB. I'm not putting any movies or music on my desktop.
Eventually, I was thinking of getting an actual NAS in raid, but again at $700 with drives, out of my price range at the moment and probably overkill for what I do and not really needed.
I think I'm probably going way overkill on trying to set up a backup system. My reports are stored in the cloud (and my computer) so I'm not really worried to bad. My business is not so mission critical that I need 24/7 raid 10 backups every 15 mins in my main computer and on a NAS. I'd be fine with 30 min backups on my computer to a single drive and then nightly backups to my external on the router.
If both hard drives in my main computer shit the bed, I'd still have to wait to order a new drive anyways. I can transfer inspection software to wife's computer in about a day (depending on tech support to issue new key). I could still do inspection from phone, just couldn't finish report until desktop switch was finished. Not a huge deal.
