Question Many many problems
Callan123
36
Hi, most of my problems started in the last 3 months.
So probably the biggest problem is the fps drops and stuttering in CS:GO. It is normally at 200-300 fps and then it will drop to 20fps and I can't move my mouse while it does this for about half a second. It seems to be worse playing with other people but it still happens with bots. The second problem is when I turn it on most of my led fans flicker at full brightness and then go dim and stay dim, just really strange. Another problem when I turn it on or restart it sometimes it will have a purple haze of the screen like a damaged cable but it only happens when it turns on, unplugging and plugging the in the cable fixes this. Sometimes when I turn the computer on my keyboard won't work so I have to keep plugging it to different USB ports until it works. I also had very bad ghosting but that has gone away.
Thanks
SPECS:
I7-3770
GTX 970
16 GB
Intel DQ77MK
Be Quiet Pure Rock Slim
FSP RA-650 Raider
