[SOLVED] Matrexx 70 RGB Case HELP
Kevin257
18
Hello,
I'm having a difficult time controlling the front fans and led strip RGB from my motherboard. I am not sure if I connected the header wrong, but after connecting the cables that came with the case to the daisy chain, I am left with a 3 pin VDG connector. Any help would be great. The motherboard I am running is the b450 Aorus pro wifi. I connected the VDG connector to the D_LED_V_SW2 header on the motherboard. The fans light up but I can't sync it with the rest of my components. Thank you!
View: https://imgur.com/a/c2byJfa
Thanks!
Maybe this has something to do with it,
and a pic from the Matrexx 70 site showing that it needs to be connected to the motherboard, so maybe somewhere in the chain you made a mistake or maybe just too many parts in the chain,
Latest posts
